pix/ospf
Sep 17th, 2005
i am wondering how to configure ospf interface md 5 authentication on a pix ver 6.3...
at the same time, is it posible to set the pix as DR without doing any config at any of its peers, only one the pix. If so, what do I do?
thanks in advance
mehrdad Sat, 09/17/2005 - 10:01
  • Bronze, 100 points or more
routing interface interface_name
Subcommands to the routing interface command:
ospf authentication message-digest
ospf message-digest-key key-id md5 key
ospf priority number
jenseike Sat, 09/17/2005 - 10:06
thanks man.. this was exactly what I was looking for..
I have one more Q to this. If I want summarize some networks after they are redistributed from my lan to my dmz... what to do..
thanks againb
mehrdad Sat, 09/17/2005 - 10:24
you can be able summarize intra-area routes through :
area area_id range address netmask
jenseike Sat, 09/17/2005 - 10:41
do you do this summarization in the ospf process where i am redistributin to since this should be after redistribution ?
