3750 stacking
thisisshanky Tue, 09/20/2005 - 20:59
  • Purple, 4500 points or more
Hunt,
Notice that if you put cable management units (single or double) between each switches, the first switch and last switch inthe stack might be too far away. Each cisco 3750 switch comes with a 50 cm stack cable. If you think that the distance between the stack connectors of the first and last switch in the stack is more than 50 cm, you will need to buy a 1 m stack cable for extra $$$. Keep that in mind.
