Warning message
Multiple PPTP Client Connections Thru Router to VPN Concentrator
I have a router set up for internet connection, using PAT. Only one user(client vpn using MS client)can connect thru the router to a VPN concentrator 3005. Is there a configuration/software fix for this?
I have tested with a W2K3 PPTP server and a Pix 501 acting as a PPTP server, they will both allow multiple connections to them thru the router but not the concentrator. Thank you.
mchin345 Tue, 09/27/2005 - 10:24
  • Silver, 250 points or more
Concentrator will not support multiple pptp sessions from behind a single PAT gateway device.
