09-25-2005 07:02 AM - edited 03-03-2019 12:09 AM
what is disadvantages of dot1Q ...?
cisco switches support both ISL and dot1Q but is there any special case where we can prove ISL is superior than dot1Q??????????
09-25-2005 07:07 AM
Hi Devang,
There is no advantage of isl over dot1q. Infact ISL increase the size of the frame by 30 bytes which includes 26 byte of header and 4 byte of tailer.
Dot1q just uses 4 bytes of internal tagging which does not affect the size of the frame much.
Also dot1q is open standard so can be used between multivendor switches.
Ankur
09-25-2005 06:09 PM
Also ISL is cisco proprietary and you cannot use ISL to connect to other vendors equipment whereas dot1q is the standard.
