Warning message
Digit Timeout - what service parameter
Answered Question
Sep 27th, 2005
The phone goes back to dial tone after about 2 seconds in the middle of
referencing a phone number to dial. Example, 724 (after a few seconds it goes to dialtone). Is there a service parameter to adjust this time.
I know there is the Off-hook to first digit parameter, but is there a parameter for any digit that follows the first? Thanks.
Correct Answer by rnarayana about 11 years 10 months ago
Is this an internal number or external number.If it is external number then that means calmanager is finding a match after 724 and it is giving a dialtone.
If you are looking for interdigit timeout it is T302.But I don't think that is the problem
Radhika
Overall Rating: 4 (1 ratings)
Correct Answer
rnarayana Tue, 09/27/2005 - 06:53
  • Bronze, 100 points or more
Radhika
