Warning message
2 internet providers.... Best to use another zone or another Pix ?
Sep 28th, 2005
Hello
My company bust baught another ISP connection.
Their idea is to use it for some web servers. My idea would be to set up an sort of internet failover ,)
But that's not my point right now :
Should i set up another zone on my current PIX witch means buying an new 4 ethernet card (as i already use the 4 zones) or should i buy another pix (a 2 zones only would be enought).
I have also read about "source adress routing" and setting 2 ips for an interface ?
Any onfo on that last part would be welcome as well ,)
Thx for your time
nkhawaja Sun, 10/02/2005 - 18:16
  • Cisco Employee,
pix doesnt have the concept of 2 ip on an interface. neither do two default routes works.
you should consider the internet failover on the routers connect the router to the pix
source address routing is not there on pix
