Warning message
Caller ID Question!
Sep 28th, 2005
  • Community Spotlight Award,
    Spanish Member's Choice: May 2016
When I call to the IP phone from any number I get the number on my screen without problem, but when I call from another extension inside I see "private" . Example
I call fromm 269-8054 I get this number but if I call
74556 wich is an extension I get private. How can I solve this issue?
I'm using a .T Pattern
Leo
ciscogini Wed, 09/28/2005 - 11:53
Is is it Call Manger or CCM Express you are aksign the question on.
If it is Call manager youy shoudl eb able to change this under the line configuration of that phoen from which you are calling
Leonardo A Pena... Wed, 09/28/2005 - 12:30
I'm using CCME.
How can I do this?
Regads
