Warning message
NVRAM Error saving config on Cat2950
Sep 29th, 2005
After making an update to the config on a couple of Cat2950 switches running IOS 12.1(13)EA1, we attempt to "copy run star" but see the following:
switchA#copy ru st
Destination filename [startup-config]?
Building configuration...
% Warning: Saving this config to nvram may corrupt any network management or security files stored at the end of nvram.
Continue? [no]:
[OK]
I have already tried the "service compress-config" but get the following:
switchA(config)#service compress-config
Boot ROMs do not support NVRAM compression.
Disabling service compress-config.
Issuing "dir nvram" reveals:
switchA#dir nvram:
Directory of nvram:/
22 -rw- 11754 <no date> startup-config
23 ---- 0 <no date> private-config
Issuing "show file system" reveals:
switchA#show file system
File Systems:
Size(b) Free(b) Type Flags Prefixes
* 7741440 2853376 flash rw flash:
- - opaque ro bs:
7741440 2853376 unknown rw zflash:
32768 - nvram rw nvram:
- - opaque rw null:
- - opaque rw system:
- - network rw tftp:
- - opaque ro xmodem:
- - opaque ro ymodem:
- - network rw rcp:
- - network rw ftp:
For now I am copying the config to tftp as a precaution, but really need to figure this out.
Thanks for any suggestions you may have.
John Rumball, CCNA
Sudbury Regional Hopsital
Overall Rating: 5 (1 ratings)
John Rumball Thu, 09/29/2005 - 08:01
Thanks very much. That's right on!
In the future, I must remember to search for bugs as I have a nack for stumbling across them. ;-)
