Warning message
Marking down VC from AF41 on the LAN to AF31 for the WAN
spremkumar Fri, 09/30/2005 - 21:09
  • Red, 2250 points or more
hi
if your switch is already marking this VC calls as COS 4 and sending it to your router then you can define a class map matching all the cos4 marked traffic and set cos 3 under the policy map while remarking.
Place the service policy on the outgoing interface facing your SP side...
just try this out and revert back how it goes...
regds
spremkumar Sun, 10/02/2005 - 19:52
do find some sample config lines which can help u out..
class-map match-any test
match cos 4
policy-map test
class test
set dscp af31
Apply this policy map under your wan interface connected to the remote site.
apply it in the outbound direction...
interface serial 1/0
service-policy output test
hope this helps ...
regds
