Brandon Buffin Mon, 10/03/2005 - 09:38
  • Purple, 4500 points or more
CDR Analysis and Reporting can do the job. You could go to CDR -> Search -> By User/Extension. You could also go to Device Reports -> Gateway -> Detail, choose the gateway(s) that you are interested in, export this report to Excel and filter based on extension.
Hope this helps.
Brandon
ciscoVOIP7960 Tue, 10/04/2005 - 09:28
Hi All,
I need to monitor voice conversations. And I was wondering if there is anything that I can use monitor phone conversations. For example, when a caller says HELLO to the callee I need to see the word "HELLO" in hex or binary.
Is there any software that I can get to do this?
Paul
sgelli Tue, 10/04/2005 - 10:43
  • Cisco Employee,
Hello Paul,
The rtp (voice packets) stream flows from the IP phone to IP phone (or voice gateway as the case may be). It does not go through the CallManager. The best method is to use a sniffer (and sniff the packets on the switch port connected to the IP phone).
Hope that helps.
Srikanth
ciscoVOIP7960 Tue, 10/04/2005 - 11:33
Thanks Srikanth!
So which sniffer program would you recommend? I was thinking about Ethereal! Is that possible with that software? Do you have any better recommendation(s) or even some helpful links?
Thanks Again!
Paul
sgelli Tue, 10/04/2005 - 14:00
  • Cisco Employee,
Hello Paul,
Ethereal or SnifferPro works fine to see the RTP stream.
Srikanth
