problem to configer aim-cue
Oct 3rd, 2005
I have router c2821 with ccme 3.3 , IOS is 12.4(2)T.I,m install aim-cue to the router and
when I want to connect in cue to config cue the router has reboot.
Any idea ?
I had an issue recently with an AIM-CUE giving me memory exceptions when I attempted to connect to it using the service-module service-engine 0/0 session commnad. Try a full power off reboot of the router to fully reset the CUE module, then when you try to session into the AIM-CUE try using telnet to connect to the router. Getting a session to the AIM-CUE from a console connection before it was configured would lock up my console port on my router, but if I connected to the router via telnet first it seemed to work fine.
Markus Schneider Wed, 10/05/2005 - 10:01
  • Cisco Employee,
A 'show version' and 'show stack' from the router would also be good. Then we can take a look at the crash. Most likely this would be better handled in a TAC case since there's probably some defect that should be linked to. Right now I'm not aware of any such issue where the system would just reboot (does it do this constantly?) with the AIM-CUE installed with that version of IOS.
h.debelak Thu, 10/06/2005 - 09:52
sh ver and sh stack are here:
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(2)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 23-Jun-05 22:32 by kellmill
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
CCME uptime is 4 hours, 30 minutes
System restarted at 15:16:12 CETDST Thu Oct 6 2005
System image file is "flash:c2800nm-spservicesk9-mz.124-2.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2821 (revision 53.51) with 249856K/12288K bytes of memory.
Processor board ID FCZ0928701W
2 Gigabit Ethernet interfaces
31 Serial interfaces
4 ISDN Basic Rate interfaces
1 terminal line
1 Channelized E1/PRI port
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
Minimum process stacks:
Free/Size Name
4752/6000 USB Startup
5204/6000 VIC_BRI_I3086 BACKGROUND
5332/6000 SPAN Subsystem
5156/6000 DIB error message
2308/3000 allegro libretto init
3224/12000 Init
59136/60000 script background loader
5340/6000 vidb clone Process
5148/6000 RADIUS INITCONFIG
2104/3000 Rom Random Update Process
1292/6000 TFTP Server
56836/60000 AFW_application_process
8980/12000 HTTP CP
Interrupt level stacks:
Level Called Unused/Size Name
1 360363 5848/9000 Network interfaces
2 176703 8560/9000 DMA/Timer Interrupt
3 1 8288/9000 PA Management Int Handler
4 4 8616/9000 Console Uart
5 0 9000/9000 External Interrupt
7 4088802 8568/9000 NMI Interrupt Handler
Markus Schneider Sat, 10/08/2005 - 14:09
  • Cisco Employee,
Thanks. Does this always happen when you session to the AIM-CUE? I.e. does the box stay up if you don't do that?
h.debelak Sun, 10/09/2005 - 00:23
yes it happens only when I'm session to the AIM-CUE.
Markus Schneider Sun, 10/09/2005 - 03:51
  • Cisco Employee,
Sorry for all the questions...do you have the configuration, as well? This looks like it may be something new, so I'm wondering what's so special about this particular deployment.
Markus Schneider Fri, 10/07/2005 - 12:11
  • Cisco Employee,
This stack trace doesn't help because the last startup cause was power-on (i.e. it was powered off an on so the stack trace of the crash was lost). We either need to get the actual stack trace of a crash, or a log of the thing as it's rebooting since it should be spitting out error messages or something as it's going down.
