Warning message
Cat 6000 bug ??
Oct 4th, 2005
  • Purple, 4500 points or more
Anyone else seen this . Running Cat 6000 sup2 running 7.6.12 code . I copy the config into bootflash (default and non-default) . When I go to look at it with the "show file bootflash:filename" it will show like 1 page of the config and then just freezes and won't show the rest. Any ideas or is it a bug ??
glen.grant Tue, 10/04/2005 - 07:55
Seems to be a problem with the more function, if you set length 0 then it will read thru the whole file. If you set it to like 24 then that's all it will read . Tried space bar ,enter key , etccc these normally work.
