Warning message
802.1X with MAC Address authentication ?
Answered Question
Oct 5th, 2005
Dear All :
Does 802.1x support using MAC address Authentication ?
Or Somebody know how to implement ?
Thanks All !!
B/R
Ted Wen.
Correct Answer by amit-singh about 11 years 10 months ago
Hi Ted,
802.1X supports the port-based autehnticaion only but you can use it along with port-security to limit the MAC-addresses on the ports.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12119ea1/3750scg/sw8021x.htm
HTH,
-amit singh
Overall Rating: 3 (1 ratings)
