LACP across two switches
Oct 5th, 2005
Is it possible yet to etherchannel (using LACP) from a server using Broadcom NICs (with the latest drivers and software) to two Cisco switches?
I heard that etherchannel has evolved but not sure to what extent. Thanks.
Georg Pauwen Wed, 10/05/2005 - 11:35
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
I assume you are referring to multichassis LACP Etherchannels, that is, each NIC going into a different switch, and both links forming a channel ?
GP
pykim Wed, 10/05/2005 - 12:37
That is correct. Is it possible yet? Thanks.
Georg Pauwen Wed, 10/05/2005 - 12:56
    2017 WAN
TMBK, the only way to configure an Etherchannel (wether PAgP or LACP doesn´t matter) is across a stack, because apparently that is the only way the channel group interface knows that it belongs to ports on different physical switches...
I will ask around if that has changed and let you know.
GP
