Warning message
CCME3.2 CUE2.1 External Transfer to Voicemail
Answered Question
Oct 7th, 2005
When reception receives an external call and forwards this call to an internal number;
1. After the ring timeout the external caller receives a message that there is no mailbox associated with the internal number.
2. This also happens if the internal number is set to call forward to voice mail
3. When internal numbers are called by their DID from outside voice mail works fine.
4. Internal calls to voicemail work fine
Any help would be much appreciated.
Correct Answer by Markus Schneider about 11 years 10 months ago
It may help to post the config to see if there's a better way to do this, although I bet if you go into CUE and configure the 'external' number for the receptionist user as an E.164 number (can be configured under the User in the GUI, or via the CLI in configuration mode--"user phonenumbere164 1234.."). Then it'll recognize either number as being associated with the receptionists mailbox.
Overall Rating: 5 (1 ratings)
Correct Answer
Markus Schneider Fri, 10/07/2005 - 11:43
  • Cisco Employee,
agtmcgarry Tue, 10/11/2005 - 05:44
Thanks for the post.
I went into every user account and entered their full E.164 number and it worked perfect.
Much appreciated.
Markus Schneider Fri, 10/21/2005 - 08:25
  • Cisco Employee,
The only thing that's different is that for the external call, CUE is being presented with a different number (in the redirected number field) than the internal call. So if you're calling extension 1000 from the "inside", CUE is presented with the last redirected number field of 1000, which it can route the correct user based on that extension. When the call comes in from the 'outside', the switch (CME or whatever) is setting the redirected number field as something else, and therefore you either have to reconfigure CME to work properly, or you have to tell CUE (via the E164 number field) to recognize that other number as being associated with the same mailbox as 1000.
