Warning message
Chris Deren Fri, 10/07/2005 - 12:12
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
If you mean on Callmanager then go to System->Date/Time and you can modify the format there.
Chris
francis.labelle... Fri, 10/07/2005 - 17:17
yes I already know that, but what I want is in the format dd-mm-yyyy (4 digit for the year!!!)
lexiainfo Sat, 10/08/2005 - 00:06
System- click on Date Time then you will see Date Format. Click the drop down menu you will see what you looking for.
francis.labelle... Sat, 10/08/2005 - 12:28
The only format available use 2 digit for the year, what I want is 4 digit : DD-MM-YYYY
lexiainfo Sat, 10/08/2005 - 16:49
Oh i see. Ok the only thing you can do is leave a feedback to cisco company and give your opinion regarding your option.
They may upgrade this option maybe in next CCM version if they feel to do so.
You can also email and let them know if they can customised that particular drop down option for you perhaps you will get some patch from them.
You can also edit this file datetimegroup.asp according to your needs. If you know bit about web programming. But i am not sure whether the file will update to your needs or not. But still you can still before you try take a backup of that file
lexiainfo Sat, 10/08/2005 - 17:14
Just know i did you can customised no need to contact cisco. Ok here are the instructions.
1. Go to start
2. Click on Search
3. Then Files or Folder
4. Type the file name "datetimegroup.asp" click on search now button search result will find "datetimegroup.asp" for you.
5. Right click that file, open that file with notepad
6. Press ctrl F (find window will open)
7. In Find window type - [email protected]@Y then click find next
button.
8. Then replace the format to [email protected]@YYYY and save
the file
9. Then goto CCM Admin page Click on Systems-
DatetimeGroup-Add new group.
10.There you go you can see in the drop down menu.
Everyone will be laughing
I hope this will help have a good weekend
