Rate-limiting on a switch
Answered Question
is there an equivalent to the rate-limit command of a router interface for a 3550 switch (l2 port).
Let say I don't want a device to eat more then 2 mbps of traffic...
Correct Answer by szahid about 11 years 4 months ago
There is no rate-limit command on 3550 , but you can rate limit traffic on a per port basis using policers. If you want the inbound traffic to be limited to 2 Mbps , you can do something as simple as following.
Define an acl classifying the traffic coming on this port.
access-lists 100 permit ip host x.y.z.w any
then define a class-map
class-map match-all ratelimit
match access-group 100
Define a policy map.
policy-map rate
class ratelimit
police 2000000 64000 exceed-action drop
and then apply this policy under the interface.
interface
service-policy input rate
3550 also supports egress policies , but you can not use acl based classification. Classification based only on dscp values can be used for egress policers.
For more information , please take a look here.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12120ea2/3550scg/swqos.htm
Hope this helps.
Salman Z.
Overall Rating: 5 (1 ratings)
Correct Answer
szahid Sat, 10/08/2005 - 20:41
policy-map rate
class ratelimit
interface
Hope this helps.
Salman Z.
pgasparovic Thu, 01/05/2006 - 09:12
Hello Salman,
I wonder about your statement that it's running the way you present.
1) First, you just use an IP ACL, what's untrue when compared to what this doc states :
http://www.cisco.com/en/US/customer/products/hw/switches/ps646/products_tech_note09186a00800feff5.shtml
saying that two ACLs, IP and MAC are needed to limit all port traffic.
2) It's not known which of EMI or SMI images is the "chosen one" to deliver the function, because the doc states that policing is available for either version.
It's probably a cheat, because we manage to run it only with EMI image.
