Warning message
A strange DTP infomation
Oct 9th, 2005
I have 2 switchs: Cat2950 and Cat3550 connected via Fa0/10
On my cat2950, i configure port fa0/10 to mode dynamic auto and the other end
with dynamic desirable. The trunking works fine but when i look at dtp
information, i see something strange:
DTP information for FastEthernet0/10:
TOS/TAS/TNS: TRUNK/DESIRABLE/TRUNK <---trunking is on
TOT/TAT/TNT: 802.1Q/802.1Q/802.1Q <---encap dot1q
But int the statistics:
2204 native, 2204 software encap isl, 0 isl hardware native <-----what does this mean: 2204 packets encap isl ? ---->
we all know that cat2950 does not support isl, so what does this infomation mean ?
Switch3550#sh run int fa0/10
interface FastEthernet0/10
switchport mode dynamic desirable
end
Switch3550#sh dtp int fa0/10
Neighbor address 1: 000C85A5700A
Neighbor address 2: 000000000000
Hello timer expiration (sec/state): 9/RUNNING
Access timer expiration (sec/state): 279/RUNNING
Negotiation timer expiration (sec/state): never/STOPPED
Multidrop timer expiration (sec/state): never/STOPPED
FSM state: S6:TRUNK
# times multi & trunk 0
Enabled: yes
In STP: no
Statistics
2200 packets received (3 good)
2197 packets dropped
0 nonegotiate, 0 bad version, 2197 domain mismatches,
0 bad TLVs, 0 bad TAS, 0 bad TAT, 0 bad TOT, 0 other
4408 packets output (4408 good)
2204 native, 2204 software encap isl, 0 isl hardware native <-----what does this from: 2204 packets encap isl ? ---->
0 output errors
and this is on Cat2950:
Switch2950#sh run int fa0/10
Building configuration...
Current configuration : 69 bytes
switchport mode dynamic auto
end
Switch2950#sh dtp int fa0/10
TOS/TAS/TNS: TRUNK/AUTO/TRUNK
Neighbor address 1: 000DBCA8838A
Hello timer expiration (sec/state): 25/RUNNING
Access timer expiration (sec/state): 294/RUNNING
FSM state: S6:TRUNK
Enabled: yes
In STP: no
Statistics
2212 packets received (12 good)
2200 packets dropped
0 nonegotiate, 0 bad version, 2200 domain mismatches,
2208 native, 2200 software encap isl, 0 isl hardware native
0 output errors
0 trunk timeouts
4 link ups, last link up on Mon Mar 01 1993, 04:26:15
3 link downs, last link down on Mon Mar 01 1993, 04:25:43
Yes,u r right.right from 2950 series switches, they don't support ISL, support only 802.1q.But,check out the version of the ios in your switches.
Do u get any of the error messages like the one below from 3550.if so, a remedy is also provided here.
Error Message DTP-5-ILGLCFG: Illegal config (on, isl--on, dot1q) on [chars].
Explanation This message means that one end of the trunk is configured as on, ISL, and the other end is configured as on, 802.1Q. [chars] is the interface.
Recommended Action This configuration is illegal and will not establish a trunk between two switches. You must change the encapsulation type so that both ends of the trunk match
ntrung Wed, 10/26/2005 - 02:06
Unfortunately, i didn't get any error message as you listed above.
The 2950 running 12.1(22)EA1 and 3550 running 12.2(25)SEA.
I was thinking that it's an ios bug maybe ???
SW3550-2#sh ver
Cisco IOS Software, C3550 Software (C3550-I5Q3L2-M), Version 12.2(25)SEA, RELEAS
E SOFTWARE (fc)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 25-Jan-05 18:57 by antonino
ROM: Bootstrap program is C3550 boot loader
SW3550-2 uptime is 8 hours, 22 minutes
System image file is "flash:/c3550-i5q3l2-mz.122-25.SEA.bin"
Cisco WS-C3550-24 (PowerPC) processor (revision J0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0746Y0KD
Last reset from warm-reset
Running Layer2/3 Switching Image
Switch_6#sh ver
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA1, RELEASE SOFTWARE
(fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 12-Jul-04 08:18 by madison
Image text-base: 0x80010000, data-base: 0x8055C000
ROM: Bootstrap program is C2950 boot loader
Switch_6 uptime is 2 hours, 16 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA1.bin"
cisco WS-C2950-24 (RC32300) processor (revision G0) with 20873K bytes of memory.
Processor board ID FOC0806Z177
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
