Warning message
pptp tunnel through an IPSEC tunnel on 3015
Using the Cisco VPN Client to build an IPSEC tunnel to a Cisco 3620 (IOS 12.3) and then a pptp tunnel through the IPSEC tunnel works perfectly. We are currently migrating from the 3620 to a 3015 concentrator. The client builds the IPSEC tunnel and also the pptp tunnel but no data is transfered!!!! Using pptp by itself works perfectly. Is this a bug or a feature? I have found nothing in the documentation which adresses this issue, hence this call for help!!!!
thomas.chen Fri, 10/14/2005 - 05:34
  • Silver, 250 points or more
The issue nay be due to second pix is missing the sysopt permission connect-ipsec command. All inbound sessions must be explicitly permitted by an Access Control List (ACL) or a conduit. The sysopt connection permit-ipsec command is issued to permit all inbound IPSec authenticated cipher sessions.
