Warning message
3750-PoE bricked - Magic number mismatch?
I have a 3750 PoE which I was trying to get the image off by doing a archive upload-sw...... but as it got to the image file it said the file/device was busy and gave up.
I executed the reload command and since then I've had this error message which doesn't allow the switch to boot its IOS:
switch: boot
Loading "flash:c3750-i5-mz.121-19.EA1c/c3750-i5-mz.121-19.EA1c.bin"...flash:c375
0-i5-mz.121-19.EA1c/c3750-i5-mz.121-19.EA1c.bin: magic number mismatch: bad mzip
file
Error loading "flash:c3750-i5-mz.121-19.EA1c/c3750-i5-mz.121-19.EA1c.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
switch:
Need to add some more info..
My options:
switch: ?
? -- Present list of available commands
boot -- Load and boot an executable image
cat -- Concatenate (type) file(s)
copy -- Copy a file
delete -- Delete file(s)
dir -- List files in directories
flash_init -- Initialize flash filesystem(s)
format -- Format a filesystem
fsck -- Check filesystem consistency
help -- Present list of available commands
load_helper -- Load and initialize a helper image
memory -- Present memory heap utilization information
mkdir -- Create dir(s)
more -- Concatenate (display) file(s)
rename -- Rename a file
reset -- Reset the system
rmdir -- Delete empty dir(s)
set -- Set or display environment variables
set_bs -- Set attributes on a boot sector filesystem
set_param -- Set system parameters in flash
sleep -- Pause (sleep) for a specified number of seconds
-- MORE --
trap -- Cause a software breakpoint to occur
type -- Concatenate (type) file(s)
unset -- Unset one or more environment variables
version -- Display boot loader version
switch:
dir of the flash:
switch: dir flash:
Directory of flash:/
2 -rwx 5 private-config.text
3 -rwx 2413 config.text.renamed
4 -rwx 5 private-config.text.renamed
5 drwx 192 c3750-i5-mz.121-19.EA1c
85 -rwx 616 vlan.dat
87 -rwx 2178 config.text
9960448 bytes available (6038528 bytes used)
switch:
Can anyone tell me how I can get this booting again? I can't see any options to download code to correct this like I would using ROMMON.
Cheers.
