Warning message
RMON traps sent as syslog
Oct 12th, 2005
I would like to pose you a question.
I have a 7200 router with image c7200-k4p-mz.120-31.S1.bin
When the wan link RMON threshold is reached, the router does send Syslog messages (sent to the logging server) and not traps (to the snmp-server host), despite the fact that the configuration does specify the trap.
I did also try with the log trap command but again, only a Syslog message is sent, not a trap to the snmp-server host list).
This has been verified with a Sniffer trace.
The RMON configuration looks like the following:
rmon event 10 trap public description "Rising Event for ifOutOctets" owner admin
rmon alarm 10 ifOutOctets.4 30 delta rising-threshold 10500000 10 falling-threshold 7500000 10 owner admin
Is this a bug, a misconfiguration or a "normal" behaviour?
snmp config:
snmp-server community <removed> RO 98
snmp-server community <removed> RW 99
snmp-server trap-source Loopback0
snmp-server packetsize 1024
snmp-server location answ
snmp-server contact xxx
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps hsrp
snmp-server enable traps config
snmp-server enable traps entity
snmp-server enable traps copy-config
snmp-server enable traps cpu threshold
snmp-server enable traps envmon
snmp-server enable traps syslog
snmp-server enable traps ospf state-change neighbor-state-change
snmp-server host 172.30.15.4 <removed>
snmp-server host 172.31.12.75 <removed>
snmp-server host 172.31.2.139 <removed>
snmp-server tftp-server-list 21
So,there is nothing send to the SNMP server.How come?
Anyone who can help?
Kurt
smahbub Tue, 10/18/2005 - 07:27
  • Silver, 250 points or more
Routers ordered without RMOn option does not send RMON traps to server. The routers with RMON option is 2500 and AS 5200. For routers without RMON option,it is better to configure alarm and event capability to send traps to server.
