Probleem getting SDM to work with tacacs (using ACS)
Oct 12th, 2005
I'm having a problem getting in SDM through tacacs (acs 3.3) Logging in via CLI (tacacs) works fine. When i put http authentication to local all works fine, I'm using the following sttings:
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ enable
aaa authentication ppp default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 default group tacacs+ local
aaa authorization commands 15 default group tacacs+ local
aaa authorization network default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
ip http authentication aaa login-authentication default
ip http secure-server
tacacs-server host x.x.x.x
tacacs-server directed-request
tacacs-server key XXXXXX
debug tacacs gives me the following when i'm trying to log into sdm --> included in the attachment
according to the output
user authentication (login/pass) goes fine
In tacacs i'm not getting any useful logging (no failed attempts, no accounting or administration output)
acs usersettings:
advanced tacacs+ settings:
max privilige = 15
tacacs+ settings:
shell exec = checked
googling and searching for 2 days now, but no luck yet
any help would be greatly appreciated!
gr,
Dennis
Richard Burts Wed, 10/12/2005 - 08:55
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Dennis
I am not clear about what the problem is. Looking at the debug output that you posted I wonder about the lines around the entry about inapproproate protocol:
*Oct 12 13:16:25.539: TPLUS: Inappropriate protocol: 24
but other than this the debug output looks like the login should have worked. I see a PASS for authentication and a PASS for authorization.
I wonder what would happen if you changed the config from:
to:
ip http authentication tacacs
Rick
dkrijgsman Wed, 10/12/2005 - 10:56
Hi Rick
"ip http authentication tacacs" isn't a option. The "inappropriate protocol 24" i also noticed, but other successfull cli logins did have the same output.
However I finally found the problem. Earlier i found this topic:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Security&topic=AAA&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.ee96430/2
Here they give the tacacs user privilige level 15 en check "exec" in de tacacs+ setting, as it seems that SDM needs privilige level 15 to get started!?. I didn't notice this earlier, so once i gave my test user privilige level 15 i got in using tacacs.
This however leads me to the second problem: restricting users using tacacs in SDM. Since 12.3(7)T IOS has the option of using Role Based CLI access:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_white_paper09186a00801ee18d.shtml
So now i'm trying to get tacacs to match a user to a parser view defined on the router (using the aaa attribute "cli-view_name"), just to put a lock on the privilige level 15 i have to define to get logged in into SDM in the first place. :(
Goal: finding a appropriate wat to give customers minimal access to a device using SDM en only allowing specific information to be viewed.
SDM has some pre-defined views such as "sdm_monitor" but these all have to much priviliges.
It i'll take me some research to get this working :)
Thnx
Dennis
