The age-old question... Good QoS documentation?
Oct 13th, 2005
Have looked through the forum and through Cisco docs in general. Looking for docs on the smaller Cisco routers and switches 3550,3640,3524. Also its interaction with non-Cisco gear.
Basically looking to find documentation on port numbers, classifications, queues other than the AVVID doc.
venkekri Fri, 10/14/2005 - 01:32
Hi Mark,
As far as Qos on router's are concerned, the TAC generally recommends, LLQ. The below link can help you in understanding how the LLQ works and how to configure it.
http://cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080094660.shtml
As far as Switch is concerned, i think the below link should be able to give you some idea.
http://cisco.com/en/US/tech/tk389/tk813/technologies_tech_note09186a00801558cb.shtml
Hope the above links help.
Venky
