WS-3750G-24TS and random Reboots
szahid Fri, 10/14/2005 - 12:23
  • Silver, 250 points or more
if the switch is booting on its own , there should be a crashinfo file in the flash that can be used to decode the crash. Please use the o/p interpreter to see if that helps you . Otherwsise , consider opening a TAC case.
Salman Z.
