Warning message
pix logs analysation
Oct 16th, 2005
Dear All,
i want to generate an .xls sheet report for pix logs , can anybody suggest me any log analyzation tool or some format .
if anybody doing the same pls give me format and info
Thanks in advance
Nataraj
arunsing Sun, 10/16/2005 - 22:09
You can use kiwi syslog deamon. This creates a tab delimited log file and can be copied into an excel sheet.
Arun
nataraj_v Mon, 10/17/2005 - 09:34
Hi arun
im using kiwi syslog deamon , but its generating .txt file , which i can not convert into xl sheet
do u have any idea about pix log analysation tools
Thanks in advance
regards
nataraj
arunsing Wed, 10/19/2005 - 22:37
Hi Natraj,
Open the txt file using excel. If will open text import wizard. Select the default settings and it will open the file as excel file in columns and rows.
Here is an example excel file which i imported.
Arun
jefchris Thu, 10/20/2005 - 07:07
Save yourself some time and look into sawmill. This will slice and dice your log every which way but lose.
Great program
