Authentication failure
Oct 17th, 2005
Hi Group
I am facing a problem in my CCM 3.3(4)sr2, when I press the service or directory buttons on the IP Phones registered to my CM, an authentication page appear to me asking for username and password. I tried all username and passwords and still this page not moving.
Also When I tried to access the User login page http://ip_server/ccmusers it didn’t open and the IE says this page is not authorized..
In the event viewer System log I found the below event:
Event Type: Warning
Event Source: W3SVC
Event Category: None
Event ID: 100
Date: 10/18/2005
Time: 6:55:42 AM
User: N/A
Computer: CALLMANAGER
Description:
The server was unable to logon the Windows NT account 'IUSR_Guest' due to the following error: Logon failure: the user has not been granted the requested logon type at this computer. The data is the error code.
In the event viewer Security Log I found the below event:
Event Type: Failure Audit
Event Source: Security
Event Category: Logon/Logoff
Event ID: 534
Date: 10/18/2005
Time: 6:55:42 AM
User: NT AUTHORITY\SYSTEM
Description:
Logon Failure:
Reason: The user has not been granted the requested logon type at this machine
User Name: IUSR_Guest
Domain: CALLMANAGER
Logon Type: 3
Logon Process: IIS
Authentication Package: MICROSOFT_AUTHENTICATION_PACKAGE_V1_0
Workstation Name: CALLMANAGER
Any ideas how to solve this problem
Thanks in advance
Overall Rating: 3 (1 ratings)
waleed.samir Mon, 10/17/2005 - 22:09
Yes i am using generic PC and every thing is working fine except this authentication failure. I think it is a problem in the DC directory.
Any ideas.
waleed.samir Tue, 10/18/2005 - 20:24
Hi Hin
I followed the link you have sent to me, I set the password in the Computer Management and the IIS metabase. But when I was updating the password on the Component services by using the command "cscript.exe synciwam.vbs -v"
I faces the below error
C:\Inetpub\AdminScripts>cscript.exe synciwam.vbs -v
Microsoft (R) Windows Script Host Version 5.6
Copyright (C) Microsoft Corporation 1996-2001. All rights reserved.
IIS Applications Defined:
Name, AppIsolated, Package ID
w3svc, 0, {3D14228C-FBE1-11d0-995D-00C04FD919C1}
Root, 2,
IISAdmin, 2,
AST, 0,
Soap, 0,
LoginService, 0,
Out of process applications defined:
Count: 1
{3D14228D-FBE1-11d0-995D-00C04FD919C1}
Updating Applications:
Name: IIS Out-Of-Process Pooled Applications Key: {3D14228D-FBE1-11D0-995D-00C04
FD919C1}
Error: 80110414:
Please advice.
lexiainfo Tue, 10/18/2005 - 21:11
Ok Now we are in track. lets try this you said you are using generic pc it is strongly recommend to use cisco approved hardware. However here is the procedure to solve your problem.
Modify Configuration in Computer Management
"CCMUser" should be in Group "WebUsers", check it in followin way:
1) Start->Programs->Administrative Tools->Computer Management->System Tools->LocalUsers and Groups
2) Expand "LocalUsers and Groups", select "Users", right click "CCMUser"
3) Select "Properties", check Tab "Member of"
4) Add "WebUsers"
Modify Configuration in Internet Inforamtion Service (IIS)
1) Start->Programs->Administrative Tools->Internet Service Manager
2) Select the CallManager server
3) Select the "Default Web Site"
4) Select the "CCMUser"
5) Right click "CCMUser", select "Properties"
6) In tab "Virtual Directory", Make sure "Application name" is "CCMUser"
7) In tab "Directory Security", Edit "Anonymous access and authentication
controll"
8) Check "Anonymous access", click "Edit"
9) Add "CCMUser" to "User Name:"
10) Check "Allow IIS to control password"
Let me know once you perform the above task.
lexiainfo Tue, 10/18/2005 - 21:16
Hi hiho
i have changed h.323 to MGCP please check email for more details can you solve my mgcp problem.
waleed.samir Wed, 10/19/2005 - 19:54
The problem is solved.
I made your steps but for the IUSR_Guest account and it is working fine now.
But some time i see error in the event viewer about the DCOM, what is the DCOM and what it could reflect on ?
Thanks a lot
lexiainfo Wed, 10/19/2005 - 23:36
Please open nee topic with DCOM. Also dont forget to tick on rate and solve the problem for the current post.
