Warning message
EtherChannel trunks
Oct 18th, 2005
Scenario:
I have a 4500 switch. I have a 3560 switch.
I built a 2 port etherchannel on both then configured each as a dot1q trunk.
I connected the 2 switches.
On the 3560, I removed the etherchannel by removing the channel group from the interfaces. Then removed the virtual port-channel interface.
Can this cause problems?
ankurbhasin Tue, 10/18/2005 - 10:19
  • Red, 2250 points or more
Hi Friend,
It should not create any problem. As soon as you remove the interface from port channel config it is out from channel config but one the thing what you will see is that one port will go into STP blocking state as now it is not a part of port channel and there are 2 redundant links so Spanning tree will block one port.
Ankur
glen.grant Tue, 10/18/2005 - 11:04
  • Purple, 4500 points or more
As best practice you should clear both sides , you won't then be questioning at some later date why that config is there or what is it being used for .
