10-20-2005 04:22 AM - edited 07-04-2021 11:14 AM
Is there any reason why Nokia D211 adapter fails radionetwork connectivity with Cisco AP1231G?
WLAN-network is working fine when Cisco AP1231G has connectivity with Cisco PCMCIA 350 adapter(802.11b standard)
Also, integrated LapTop wlan-circuit(like Intel's) has connectivity with Acces Point.
Cisco AP1231G(ETSI) is running IOS 12.2(15)JA
no encyption enabled
Thanks for advance!
10-26-2005 06:44 AM
Check the compatability with NOKIO and Cisco. Check the parameters will match the configuration which you did in the cards.
10-26-2005 12:08 PM
Hello
go first for newer ios software.
Try to setup a fix channel (1 to 11) and dont use the best throughput options for the datarate.
Some clients have trouble with it.
Hope this helps
Oliver
