Warning message
nhabib Thu, 10/20/2005 - 05:39
  • Red, 2250 points or more
If you are referring to syslog messages, then yes.
If you are referring to snmp traps, then the logging command is of no use. CiscoWorks does not do much with SNMP traps though, so you want to make sure you are sending syslog messages to CiscoWorks.
vnealy Thu, 10/20/2005 - 09:37
Excuse me but what piece in CW uses syslog? DFM?
Thanks.
