Inside routing pix 515
cisco7889
I have a problem with inside routing on a pix 515. The pix has inside ip 192.168.200.254/24 and is acting default-gate to all nodes on this net. There is also a vpn router on the inside with ip adress 192.168.200.245/24. vpn router has a default route to pix inside interface. There are coming trafik from net 192.168.210.0/24 on the vpn router and i want this to return to the vpn router with a route in the pix 515 "route inside 192.168.210.0 255.255.255.0 192.168.200.245 1" but in the pix log i get message "no route found to 192.168.210.0" I don´t understand this, maybe the static route isn´t right. I would be very grateful for an answer. /Regards Jonny
ddarby1
Nothing wrong with your route statements by the looks of it. Sh route for the PIX should have at least the two following commands in it:
inside 192.168.200.0 255.255.255.0 192.168.200.254 1 CONNECT static
inside 192.168.210.0 255.255.255.0 192.168.200.245 1 OTHER static
Don't personally like the numbering in use (easy to confuse 254 with 245), but the problem should be with some other part of the config, I'd guess.
you mentioned, "There are coming trafik from net 192.168.210.0/24 on the vpn router and i want this to return to the vpn router with a route in the pix 515 "route inside 192.168.210.0 255.255.255.0 192.168.200.245 1"".
assuming the pix receives the packet from the inside interface, pix by default will not re-route the packet back to the vpn router via the inside interface.
fzamora
Unfortunately the PIX does not route traffic through the same interface it received it. Check the link below:
http://www.cisco.com/en/US/partner/products/hw/vpndevc/ps2030/products_qanda_item09186a0080094874.shtml
Franco Zamora
I believe that with 7.X code you can do it.
