Warning message
Ciscoworks report
Oct 21st, 2005
We have 10 Routers/switches.We want to achieve the following task from Ciscoworks LMS:
1.Polling/ping the routers/switchs every 10 minutes.
2.Generate a report(graph will be better) that indicates the and the amount of total polling and success percentage. Because we want to show the manager that up/down time.
I seem can't find this within the LMS,not in DFM, not in performance monitor.
Which product from Cisco works have this capability?
Marvin Rhoads Fri, 10/21/2005 - 07:05
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 Firewalling, Network Management, VPN
I believe a device availability report is what you are looking for. Execute the Resource Manager Essentials\>Administration\>Availability\>Change Polling Options page and select at least one view to be polled for reachability information. Afterwards, wait for several polling cycles before retrying the report again.
(That's under LMS 2.2 - I don't have a 2.5 box in front of me to check the syntax but it's along those lines.)
nhabib Fri, 10/21/2005 - 07:06
  • Red, 2250 points or more
Availability was removed from LMS 2.5
Marvin Rhoads Fri, 10/21/2005 - 07:30
  • Hall of Fame,
Thanks for the correction Nadim.
Yet another reason not to upgrade to 2.5. :((
