Warning message
catalyst cluster
Oct 24th, 2005
I have two catalyst C2950SX-48-SI configured in cluster with one IP address using CLI. Now I wish to manage them by Cisco Network Assistant but only command switch is seen in gui, no member switch. How can I managed all switches in cluster using CNA ?
Georg Pauwen Mon, 10/24/2005 - 21:50
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
not knowing exactly where you get stuck, you might want to have a look at this document, check the section that describes the various cluster member discovery ways:
Getting Started with Cisco Network Assistant
Planning and Creating Clusters
http://www.cisco.com/en/US/products/ps5931/products_getting_started_guide_chapter09186a00802b7d99.html
HTH,
GP
Przemyslaw.Agac... Tue, 10/25/2005 - 02:58
Thank you Georg , but my CNA is 3.0 version and there is no exists “Cluster” option in menu. In CNA topology view there are only devices with assigned IP addresses but no cluster members (without IP). I can configure cluster using CLI and it is working fine.
PA
