Warning message
OSPF & MPLS
Oct 26th, 2005
I've 2 routers conncted via MPLS IP VPN.
I try to up OSPF between it.
1-st R-
router ospf 9
log-adjacency-changes
network 10.20.18.0 0.0.0.255 area 1
network 172.30.0.0 0.0.0.255 area 1
#sh ip ospf interface
Serial0/0 is up, line protocol is up
Internet Address 172.30.0.9/30, Area 1
Process ID 9, Router ID 172.30.0.9, Network Type POINT_TO_POINT, Cost: 64
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
oob-resync timeout 40
Hello due in 00:00:09
Supports Link-local Signaling (LLS)
Index 2/2, flood queue length 0
Next 0x0(0)/0x0(0)
Last flood scan length is 0, maximum is 0
Last flood scan time is 0 msec, maximum is 0 msec
Neighbor Count is 0, Adjacent neighbor count is 0
Suppress hello for 0 neighbor(s)
FastEthernet0/0 is up, line protocol is up
Internet Address 10.20.18.2/24, Area 1
Process ID 9, Router ID 172.30.0.9, Network Type BROADCAST, Cost: 1
Transmit Delay is 1 sec, State DR, Priority 1
Designated Router (ID) 172.30.0.9, Interface address 10.20.18.2
No backup designated router on this network
Hello due in 00:00:07
Index 1/1, flood queue length 0
Next 0x0(0)/0x0(0)
2nd R-
router ospf 21
network 10.20.24.0 0.0.0.255 area 1
GW#sh ip ospf int
Internet Address 172.30.0.21/30, Area 1
Process ID 21, Router ID 172.30.0.21, Network Type NON_BROADCAST, Cost: 64
Designated Router (ID) 172.30.0.21, Interface address 172.30.0.21
Timer intervals configured, Hello 30, Dead 120, Wait 120, Retransmit 5
oob-resync timeout 120
Hello due in 00:00:08
Next 0x0(0)/0x0(0)
Internet Address 10.20.24.2/24, Area 1
Process ID 21, Router ID 172.30.0.21, Network Type BROADCAST, Cost: 1
Designated Router (ID) 172.30.0.21, Interface address 10.20.24.2
Next 0x0(0)/0x0(0)
I don't have ospf neighboors. I tryed to select for interfsaces -
ip ospf network point-to-multipoint
or ip ospf network broadcat
but it didn't help.
I tryed to write neighboors address but get message-
GW(config)#router ospf 21
GW(config-router)#nei
GW(config-router)#neighbor 172.30.0.9
OSPF: Neighbor address does not map to an interface
Why i get that message?
christopher_for... Wed, 10/26/2005 - 05:44
Just looking at this quickly I'm seeing that the serial interfaces are not on the same subnet(assuming that these routers are connected through the serial 0/0 interfaces), which is why you would get "OSPF: Neighbor address does not map to an interface"
R1
(This /30 has two usuable IP addresses in the subnet - 172.30.0.9 and 172.30.0.10)
R2
GW#sh ip ospf int
(This /30 has two usuable IP addresses in the subnet - 172.30.0.21 and 172.30.0.22)
