How low can the security-association lifetime be?
Oct 26th, 2005
I have been working on a lab deployment before going to production. I found that I had an issue with failover until I reduced the security-association lifetime to 120 seconds on the routers connecting to a PIX. I did not change anything on the PIX
I was wondering if this is going to be an issue with 20 or so routers negotiating their SA every couple of minutes?
How low have you run the security-association lifetime setting in real life production networks?
Do you see any issues with this
jackko Wed, 10/26/2005 - 19:16
  • Gold, 750 points or more
just a quick comment.
first, pix failover should work with the default lifetime.
and second, 20 sites perform re-key every 2 mins will create too much overheads, which i believe will have an impact on the vpn.
