10-26-2005 11:50 PM - edited 03-13-2019 11:00 AM
Hi there,
just upgraded the files on our CCME kit, and 7940/60G phones now looking for the above file from the tftp server - I can't see it mentioned in the documentation - anyone have info on it?
It would appear that each line/button can have it's own ringtone assigned now, which is great, but it would be nice to know how it works!
cheers!
Solved! Go to Solution.
10-28-2005 11:22 AM
Hi Peter,
It's good that it worked after you copied the ringlist.xml file, but there is a lot of difference between the ringlist.xml file and the distinctiveringlist.xml file.
The ringlist.xml file contains ringtones which can be applied on the phones by default, but if you want any one particular line on a phone to ring differently when a call comes in, then you will require the distinctiveringlist file which contains 7 special ringtones.
So, you can make things work by using the same file, but they are created to be used differently.
Incase of any questions, please let me know.
10-27-2005 12:02 AM
DOH, forget it.
It's exatcly the same as RingList.xml, just copying the ringlist.xml file worked.
cheers,
peter.
10-27-2005 08:37 PM
Last week I set up one of these, and it asked for the same. I set the xml files under the tftp-server command and the message stopped.
10-28-2005 11:22 AM
Hi Peter,
10-31-2005 02:17 AM
thanks, now if you could only apply distinctive rings to Overlayed numbers I would be a very happy man!
It's not much use when I have 'monitor' set up on the lines on my phone!
cheers,
peter.
