mounir.mohamed Thu, 10/27/2005 - 02:58
  • Gold, 750 points or more
Dear stephtchoko,
MPLS is a great technologies it’s easy to take and running script from the internet and post it on your router then everything gone be working but it’s very nice to understand how it’s working because your life gone be under control (I mean you have to understand the technologies how it’s works to troubleshoot your network in any case)
Here is a simple configuration to get mpls working with 2 routers
Topology: Router1 Serial0 connected with Router2 via Serial2
Router1 S0/0  Router2 S0/0
((Router1))
Router1(config)# ip cef
Router1(config)# mpls label protocol tdp
Router1(config)# tag-switching tdp router-id serial0/0
Router1(config)# mpls ldp logging neighbor-changes
interface Serial0/0
ip address 172.16.1.1 255.255.255.252
no shut
tag-switching ip
((Router2))
Router2(config)# ip cef
Router2(config)# mpls label protocol tdp
Router2(config)# tag-switching tdp router-id serial0/0
Router2(config)# mpls ldp logging neighbor-changes
interface Serial0/0
ip address 172.16.1.2 255.255.255.252
no shut
tag-switching ip
please be informed that you have to use any routing protocol to start advertise the L3 information.
http://www.cisco.com/en/US/tech/tk436/tk428/technologies_configuration_example09186a0080093fcc.shtml
Best Regards,
Mounir Mohamed
mounir.mohamed Mon, 10/31/2005 - 10:52
the document is good, but is everything working with you or you facing a problem?
stephtchoko Tue, 11/01/2005 - 23:38
  • Bronze, 100 points or more
yes, ThanK.This is my first experience with this protocol (MPLS).Which type of routing protocol ( isis, ospf) do you think, it is more adapatable with mpls in isp network ?
Best regards
mounir.mohamed Wed, 11/02/2005 - 10:37
ISIS is recommended in service provider networks and it's more sclabel than OSPF
stephtchoko Thu, 11/03/2005 - 23:00
please what is main reason isis is more scalable than ospf ?
Best regards.
abdul1983 Sun, 04/16/2006 - 21:38
H r u
I am Abdul Khadeer from chennai . i had compeleted the ccna course but not certification .plz if do u have any dumps plz send it to me .so I am planing to give the exam
michaelhawkins Sun, 11/06/2005 - 05:26
Here's a copy of the configuration that I had on my two lab PE routers that was testing multicast tunneling through mpls. You will need two CE routers for a total of four routers. It's not a perfect config (the traffic engineering is only half begun) but it will get you going.
