Warning message
Aaron Harrison Fri, 10/28/2005 - 00:11
  • Community Spotlight Award,
    Member's Choice, May 2015
You could use the hidden:
csim start
To test calls, subject to all your dial-peers and so on as a real call is...
Aaron
dszymkowicz Fri, 10/28/2005 - 01:47
Thanks, it works, but is there any way to check single interface?
Aaron Harrison Fri, 10/28/2005 - 04:15
I don't think there is with that command...
What happens with the test isdn command? Is it just not there?
I think some versions of software have
test isdn call
instead of
isdn test call
Have a look...
Aaron
p.s. please rate helpful posts.
