PDM Access Denied
Answered Question
Oct 28th, 2005
When I attempt to access the PIX via PDM I am able to log into the first prompt by leaving the username blank and then typing in the enable password. Then I get a second prompt and I am unable to log on? I was able to log on before (many months ago), but, now I can't?
Should I create a new user and password? Or is there something else that I have to do?
I appreciate any help.
Thanks.
Mark
Correct Answer by fzamora about 11 years 9 months ago
You better check the PDM version you are running, I think is not compatible with the java version you are running.
Check the information below:
exception: java.security.AccessControlException: access denied
(java.util.PropertyPermission java.version read).
PIX Device Manager (PDM) versions 3.0(1), 3.0(2), 4.0(1), and 4.1(1) are incompatible with Java Plug-in versions 1.4.2_08 and 1.5.0_02 or later. If these Java Plug-ins are used in conjunction with the impacted PDM releases, the application will not load. Changes made in the Java Plug-in 1.4.2_08 and 1.5.0_02 break the existing code loading functionality in PDM and IDM.
As a workaround, the latest maintenance releases PDM 3.0(3), PDM 4.1(2), and IDM 5.0(2) resolve this issue. Another option is to uninstall the Java version your machine is running and install the one you will find by clicking on the link below:
<http://java.sun.com/j2se/1.3/download.html>
For more information check the link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps4077/products_field_notice09186a008046c805.shtml
Franco Zamora
Overall Rating: 5 (2 ratings)
Correct Answer
fzamora Fri, 10/28/2005 - 09:17
  • Cisco Employee,
Franco Zamora
belenkym89 Fri, 10/28/2005 - 10:11
Wow, that was the problem!!
Thanks for responding so fast!
I guess what I should probably do now is to update the PDM software.
Thanks for you help.
fzamora Fri, 10/28/2005 - 10:15
  • Cisco Employee,
Not a problem, have a great day!
Franco
fzamora Fri, 10/28/2005 - 10:19
  • Cisco Employee,
Don't forget to rate the post as it will help another users as well
Franco
