Warning message
PIX 525 6.3 to 7 - TFTP Copy Error !!
When trying to upgrade PIX 525 from ver. 6.3(4) to pix702.bin via the "copy tftp flash" command I'm getting "tftp: Timed out during transfer". Tried differnet servers, differnet TFTP clients & even tried differnet images (pix702.bin, pix702-5.bin)redownloaded the images several times. Checked to make sure "fixup protocol tftp 69" was enabled.
All servers on the "inside" interface with a security of 100. Listed below is the error I'm getting & the output from "sh version".
Thanks...
PIXFW# copy tftp flash
Address or name of remote host [172.16.2.24]? 172.16.2.22
Source file name [/PIX_Config.txt]? pix702-5.bin
copying tftp://172.16.2.22/pix702-5.bin to flash:image
[yes|no|again]? yes
Image not installed
Cisco PIX Firewall Version 6.3(4)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Fri 02-Jul-04 00:07 by morlee
PIXFW up 20 days 22 hours
Hardware: PIX-525, 256 MB RAM, CPU Pentium III 600 MHz
Flash E28F128J3 @ 0x300, 16MB
BIOS Flash AM29F400B @ 0xfffd8000, 32KB
Encryption hardware device : VAC (IRE2141 with 2048KB, HW:1.0, CGXROM:1.9, FW:6.5)
0: ethernet0: address is 0008.21e6.926d, irq 10
1: ethernet1: address is 0008.21e6.926e, irq 11
2: ethernet2: address is 00e0.b604.50d5, irq 11
3: ethernet3: address is 00e0.b604.50d4, irq 10
4: ethernet4: address is 00e0.b604.50d3, irq 9
5: ethernet5: address is 00e0.b604.50d2, irq 5
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 8
Maximum Interfaces: 12
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
fzamora Mon, 10/31/2005 - 07:53
  • Cisco Employee,
Got the same problem a few times, best thing to do, go ahead and try the upgrade from monitor mode. If you cannot take the PIX to monitor mode try the following:
-download this tftp application (tftpd32) from http://tftpd32.jounin.net/
-extract the exe and change the "current directory" option to C:
-place the bin file on the C: drive
-issue the command clear tftp
-make sure you can ping the system running the tftp application and make sure the host is not running any
antivirus or built in firewall
-try it again
I hope it helps
Franco Zamora
hsajwan Mon, 10/31/2005 - 11:18
Yes, francozamora is correct. tftpd32 is the well known tftp server and recommended as well.
Also make sure you are not running two tftp servers.
