Cisco VPN client and Sygate Firewall
Nov 1st, 2005
I Installed Cisco VPN client 4.0.3(F) to make connection to University. This solution worked fine.
Then I installed Sygate Personal Firewall Pro 5.5 newest build and VPN doesn't work anymore.
Now Cisco VPN client says when connecting to UNI that firewall policy mismatch and I should enable Integrated client.
Cisco log files says that Integrated Client cannot be loaded.
How do I solve this problem.
jackko Tue, 11/01/2005 - 03:32
  • Gold, 750 points or more
create an exception rule on the sygate firewall permitting the followings:
udp 500
udp 4500
ip 50
johnd2310 Wed, 12/07/2005 - 20:29
  • Silver, 250 points or more
uninstall Sygate and install ZoneAlarms firewall. This should fix your problem
