Warning message
Outside line without prefix CME
Answered Question
Nov 1st, 2005
I am configuring a demo system on a 2811 router with bri interface. I would like to avoid prefix for an outside line. The local phones are numbered 201 to 236.
Right now the dial-peer conf is
dial-peer voice 1 pots
destination-pattern [2-9].......
incoming called number xxxxxx
direct-inward-dial
port 0/0/0
This works ok. I gets and recieves calls, as log as i dont try to call numbers starting with 201 to 236.
Is there any way to tell the router that it should consider calls to numbers longer than 3 digits to be to the outside world ?
/Per
Correct Answer by PETER NEGUS about 11 years 9 months ago
Dear Per
What you need to do is to create two new dial peers with the following destination patterns pointing at the same voice port
destination-pattern 2[0-2]..T
destination-pattern 23[0-6].T
note the T which provides the timeout.
This may make internal calls from analog phones to have long post dial delay, as you are now having to wait for the 4th digit. You can minimise this by the command on the voice port for analogue phones.
timeouts interdigit
Overall Rating: 5 (1 ratings)
Correct Answer
PETER NEGUS Tue, 11/01/2005 - 08:57
Dear Per
timeouts interdigit
pbuch Tue, 11/01/2005 - 22:33
I get the idea !
/Per
pbuch Thu, 11/03/2005 - 02:48
But not the function :-(
No mattter what i do, as soon as 202 is dialed, i get a local phone.
debug voip dialpeer shows Partial Matches (1) as soon as the first digit is processed.
Why dosent it consider the other dial-peers stating with 2 ?
Is is totaly imposible to get this to funktion ?
/Per
