Warning message
VMS server needs manual maintainence??
Nov 1st, 2005
Folks,
I am looking at the log files in my VMS server and they are much bigger in size than the recommended values, am i use to manual clean them up or can i automate the process.
jlimbo Tue, 11/01/2005 - 21:43
There should be default database pruning values according to the version of Monitoring Center for Security you are running:
Have a look at the DB maintenance links, according to the version you are running.
2.x
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/mon_sec/secmon20/ug/dbrules.htm
1.2
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/mon_sec/secmon12/ug/ch07.htm#130530
