Warning message
portfast query
Nov 1st, 2005
i need to check if the ports in my switches are in s.tree portfast state or not. i did try the query 1.3.6.1.4.1.9.5.1.4.1.1.12 and it works fine with my Catos switches but none of my IOS switches answer to this query (cat4500,cat2950,6513).
i try to find other mibs and can't find realative one
can any of you help me.
thanks in advance.
David Stanford Tue, 11/01/2005 - 08:10
  • Cisco Employee,
You might want to look at the CISCO-STP-EXTENSIONS-MIB which is supported on these IOS based switches. It has multiple objects related to spanning tree and port state
amisu Wed, 11/02/2005 - 04:15
can you post the specific OID
i tried to download the mibs and i can't find the OID's.
thanks
