Warning message
CS-MARS Topology
Nov 1st, 2005
Why doesn't the topology show the correct connections between devices? For example I have a Router connected to an ASA applicance and it shows the router in a segment by itself even though these devices are on the same subnet.
pradeepde Mon, 11/07/2005 - 13:46
  • Bronze, 100 points or more
Enter the Access IP address and Reporting IP address (the IP address of the device as it appears to the CS-MARS) of the switch. The Reporting IP address is usually the same as the Access IP address, but if you are using FTP as Access Type, it must be a different IP address. The Reporting IP address is required if the device is sending syslog data to the CS-MARS
