Is there a IOS,CME,CUE compatibility matrix somewhere?
Nov 1st, 2005
I have a 3745 running c3745-ipvoice-mz.123-7.T1 with CME ver 3.1.1 and a NM-CUE 1.1.2. I need to upgrade the IOS to c3745-ipvoice-mz.123-11.T8. Is there a compatibility matrix that shows if the newer code is compatible with the versions of CME/CUE? Thanks.
Overall Rating: 4 (1 ratings)
Brandon Buffin Tue, 11/01/2005 - 13:54
Take a look at the following documents.
Cisco CallManager Express and Cisco IOS Software Compatibility Matrix
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/prod_release_note09186a0080524434.html
Release Notes for Cisco Unity Express 2.0 (Software Compatibility Section)
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/prod_release_note09186a0080450c0c.html#wp76155
Hope this helps.
Brandon
