Multiple VPN profiles on single router
Nov 1st, 2005
Currently i have a router that is setup to accept inbound connections from users using the cisco software vpn client, which is working fine. Now i need to expand this routers capabilities. I need it to support a tunnel to another router as well. The requirements of the new vpn connection are as follows:
Phase-1:
AES-256
SHA
Group 2
Default Lifetime
Phase-2:
AES-256
SHA
Default Lifetime
What i am looking for is a configuration example. I have no idea what to look for, or even what this is called to search cisco's site. Any advice is appreciated, i am really new to vpns.
Thanks much
Overall Rating: 2 (1 ratings)
thisisshanky Tue, 11/01/2005 - 21:54
  • Purple, 4500 points or more
How is your existing router configuration look like ? Do you have a dynamic crypto map configured on the router, which in turn is referenced by a static crypto map ? If yes, each static crypto map has an instance number and you can define multiple instances of the same static crypto map, as follows.
aaa new-model
aaa authentication login VPN-CLIENTS group radius
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp policy 2
encr aes
group 2
hash sha
crypto ipsec transform-set test-set esp-3des esp-sha-hmac
crypto isakmp client configuration group test-vpn-group
key
dns
domain
pool VPN-POOL
crypto dynamic-map test-map 10
set transform-set test-set
crypto map radius-map client authentication list VPN-CLIENTS
crypto map radius-map isakmp authorization list group-auth
crypto map radius-map client configuration address respond
crypto map radius-map 10 ipsec-isakmp dynamic test-map
crypto map radius-map 20 (For site to site vpn)
Crypto instance 20 will define site to site vpn settings, while crypto instance 10 will take care of vpn clients.
jeffdanderson Wed, 11/02/2005 - 17:26
Not sure what you call the setup that is currently on the router. I pasted the relevant parts below. I am a complete newbie when it comes to vpns. I have setup a few following some configuration examples, but my understanding is lacking. If you could show me how to integrate the 2 VPN together, that would be great.
aaa authentication login userauth local
aaa authentication login line line enable
aaa authorization network groupauthor local
aaa session-id common
crypto isakmp policy 3
hash md5
group 2
no crypto isakmp ccm
crypto isakmp client configuration group mycompanyvpn
key supersecretvpnkey
domain mycompany.domain.com
pool mycompanypool
acl 105
crypto ipsec transform-set mycompanyset esp-3des esp-md5-hmac
crypto dynamic-map mycompany-dynamic-map 10
set transform-set mycompanyset
crypto map mycompanymap client authentication list userauth
crypto map mycompanymap isakmp authorization list groupauthor
crypto map mycompanymap client configuration address respond
crypto map mycompanymap 10 ipsec-isakmp dynamic mycompany-dynamic-map
interface Serial0/0
ip local pool mycompanypool 172.17.0.1 172.17.0.100
route-map nonat permit 102
match ip address 102
access-list 102 deny ip 10.11.12.0 0.0.0.255 172.17.0.0 0.0.0.255
access-list 102 permit ip 10.11.12.0 0.0.0.255 any
access-list 105 permit ip 10.11.12.0 0.0.0.255 172.17.0.0 0.0.0.255
On the other side of the tunnel is the following private network 10.0.46.0/24. Let pretend that the VPN peer of the terminating router is 1.2.3.4
jackko Wed, 11/02/2005 - 18:21
  • Gold, 750 points or more
you can pretty much leave the existing config, except acl 102. the reason being this acl is used for no nat, so you need to add the 10.0.46.0/24.
e.g.
encr aes
group 2
hash sha
crypto ipsec transform-set newset esp-aes esp-sha-hmac
crypto isakmp key
 address 1.2.3.4 no-xauth
access-list 102 deny ip 10.11.12.0 0.0.0.255 10.0.46.0 0.0.0.255
access-list 107 permit ip 10.11.12.0 0.0.0.255 10.0.46.0 0.0.0.255
crypto map mycompanymap 20 ipsec-isakmp
set peer 1.2.3.4
set transform-set newset
match address 107
jeffdanderson Sat, 11/05/2005 - 18:17
Well i have added the appropriate commmands to the router and the tunnel isnt coming up. It hits the ACL and tries to bring up the tunnel but it fails. I have captured the output from a debug crypto isakmp. If i am reading the debug properly i think the key exchange is failing. I dont have access to the remote end so i want to confirm this before i contact the company supporting the other side. I have attached the output from the debug. Please advise.
I forgot to add the attachment and it wont let me do it after the fact. Please see the next post for the debug output.
jackko Sat, 11/05/2005 - 21:27
it would be helpful if you post the latest config.
jeffdanderson Sat, 11/05/2005 - 22:31
See attached. This should be all the relevent info. The actual config is really extensive and i dont want to make it public friendly unless i absolutely have to.
jeffdanderson Tue, 11/08/2005 - 16:57
Nobody has any suggestions? If i cant get this working soon i am going to have to resort to TAC, which i am trying to avoid.
