Warning message
CSS 11503: sticky by even and odd client IP addresses
Nov 2nd, 2005
I have two CSS 11503 and two real servers to balance. We would like to stick the clients by IP addresses, so that the even IP addresses are sticky to a server and the odd IP addresses are sticky to the other one. Is it possible ?
Gilles Dufour Thu, 11/03/2005 - 04:41
  • Cisco Employee,
this is not possible and I don't really see why you would need such a thing.
You can do sticky based on source-ip so the same source ip will always be sent to the same server.
The distribution should be even but it will not be a odd/even split.
So, all you need is 'balance srcip'
Thinking about it, you could achieve what you want with an acl and the 'prefer' option.
However, as I don't see the benefit of such distribution I would not recommend it.
Gilles.
