AS2511-RJ High cpu due to exec process
Nov 2nd, 2005
I'm having high cpu load on two access servers used to do remote console sessions to other routers. Everything it's up and running fine. Problem is that some of the lines are connected to redundant supervisor modules on Catalyst 6500's and redundant RSP's on 7500 routers. These lines are connecting and disconnecting continuosly like they are polling or something. This is causing a high cpu load on the access server, mainly with the exec process. How can I stop this behaviour? or it's something I should get used and live with it?
A clear line do close the lines, but they come back again in a few seconds.
Below is the relevant config for the AS2511:
line 1 16
session-timeout 10
login authentication Method_reverse
transport input telnet
transport output telnet
autohangup
stopbits 1
flowcontrol hardware
And is corresponding console config on the 7500 is this:
line con 0
accounting exec Metodo_acc_login
login authentication Metodo_login
stopbits 1
Thanks in advance
Carlos
