Warning message
ASA 5510 and SSM-10 module
Nov 2nd, 2005
I have a couple of questions regarding the ASA that deal with the SSM module.
I have read the document "Configuring ASA-SSM" and am confused by the command logic. I realize that you need to specify a service-policy globally that defines the traffic being sent to the SSM module. My concern is that the configuration document lists as one of it's steps to define an ACL for the IPS traffic and then apply it to an interface before configuring the class map, policy map, and service-policy. Why would this ACL need to be applied to an interface when it is being used for defining IPS traffic? Shouldn't the ASA send whatever traffic is defined globally in the service-policy to the SSM without attaching the ACL to an interface?
Also, on the ASA factory default configuration there is a service-policy defined as:
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
But, if I define a global service-policy for the SSM I would lose this default service-policy as only one global service policy is allowed. Is the default service-policy providing the fixup protocol services as in the PIX that I am used to seeing? If so do I lose this functionality by applying a global service-policy for IPS/
Sorry for the length of the post and thanks for your help in advance.
