Warning message
How to get rid of C:\Commserver folder after reinstall
Answered Question
Nov 2nd, 2005
  • Bronze, 100 points or more
HI
Unity 4.0.5
I installed Unity on C drive instead of D so used download and used UninstallUnity Tool, then reinstalled on D. However, C:\Commserver still shows up. Just in case deleting C:\Commserver would break anything, I instead renamed it to c:\OldCommserver and next time I look it recreated another C:\Commserver
How do I get rid of C:\Commserver.
Correct Answer by Hin Lee about 11 years 9 months ago
Before you delete the folder, go to Add/Remove Programs to remove Unity Uninstall program that you had installed from CiscoUnityTools.com
Overall Rating: 5 (1 ratings)
Hin Lee Wed, 11/02/2005 - 16:42
  • Cisco Employee,
What files and subfolders are under there? You may have set the logs to write to C:\Commserver\logs and that is why it is being recreated. Let me know what you see and maybe we can figure it out.
aamercado Thu, 11/03/2005 - 07:03
C:\Commserver has ONLY "UnityUninstall" folder and there is no more folders or subfolders
C:\Commserver\UnityUninstall\ <-- has 20 objects below:
8 dll files below:
4 subscriberkillerUnity30.dll (ENU, DEU, FRA, JPN)
4 UnityUninstall3xand4x.dll (ENU, DEU, FRA, JPN)
3 Bat file (test, tomcatuninstall and unityclean)
7 EXE files (instrv, kill, mypause, skinny setup, subscriberkillerunity30, unityuninstall3xand4x, versionchecker)
yshraybman Thu, 11/03/2005 - 12:37
Rename c:\Commserver folder to something else. If everything works fine go ahead and delete it. In case anything is still tied up to the folder rename it back.
Correct Answer
Hin Lee Thu, 11/03/2005 - 18:04
  • Cisco Employee,
aamercado Fri, 11/04/2005 - 07:40
removing the UnityUninstall program did auto remove the c:\commserver folder. Thanks
